Can I print directly from my 9210 to a Printer who has irda interface ?
Wich are the compatible printers ? Regards.
Print Compatibility
I am sorry that I do not know for sure. I asked Steve Litchfield from http://3lib.ukonline.co.uk/ because he always has answers. His reply is that there have always been printer driver problems, so he does not expect it to be perfect.
I am looking at getting a HP Deskjet 340 and an infrared adapter. very portable. I will let you know.
There was a place that sold infrared connectors that HP DeskJet 5xx series work with 9000 and 9000i. http://www.compusb.com/irprinadfora.html
Let me know what you think.
Thank u for your help. I'm buying an HP 340 cause I need that urgently. Hope it works. Regards.
I'd recommend that you do a search of the Forum archives - there was a thread running a while back which addressed the issue of compatible printers & drivers in a fair amount of detail.
