Besides the standard icons at the bottom of the screen, how do I create/place icons middle) on the desktop the way its shown in the Handango website?
Icons on Tracker Ver 2
Go to the Desk view on Tracker and in the top left Corner tap the View Menu then "Customize Favourites". This will bring up a grid on your desktop (2 Pages available). Tap a box on the grid and it will bring up a drop down list of your available apps. Select the app which you want and hit select and its icon will now be placed in the position on the grid that you selected. Hit done and you will return to the normal Desk view. You can now tap the icon you placed on the desktop to run the relevant app.
thanks for the reply MATAI. That is exactly what I have on my desktop right now, however I was referring to the sample on the HANDANGO website which shows the icons on a horizontal setting and a round circle. Any idea on how to configure it that way?
Just create a background with the buttons you want as part of the background image.
as much as it would have helped if you posted the url, i got it now
http://www.handango.com/PlatformProductDetail.jsp?productType=2&optionId=1_4_2&jid=ECD336D5AXDF159F9C1X6E16D4C8AAA6&platformId=4&siteId=1&productId=68847&sectionId=0&catalog=20&txtSearch=tracker
but yeah, the bubbles are part of the background, the gridlines have obviousaly been chosen to not show and you just put the icones however way you want but of course making the bubbles correspond to them
does anyone know where decent tracker backs can be downloaded?
