Want 250 kb more ram?
7 replies · 3,299 views · Started 03 August 2003
i dont know whats the safe mode but it gives 250 k more of ram when i turn on the phone and open the switcher i have 2550 kb ram but when i re turn on the phone with pushing the pencil tool its
****2800**** woow isnt it wonderful
if isnt secure please tell it because i use it
Give your opinion is you try it give me the resullts if its work or not
Save Mode is a feature that System Tools has,an app developed by www.psiloc.com .You have more RAM available because in Flight Mode the Phone app is not automaticaly started.
this isnt flight mode in flght mode i have 3260 kb this is safe mode tihs is pencil tool when you normally restart the phone as you press the on/off button you press also pencil tool and its in the safe mode try it and before trying this look at the ram that you have and after the safe mode look it again
ITS NOT THE FLIGHT MODE AT ALL because you can call and receive normally
Holding the pencil down during startup does nothing on my 3650, it just starts as normal and looks like there is the same amount of ram available
(3282kb)
Anyone else with a Uk 3650 find the holding the pencil does anything?
DO you really have 3280 how can it be i dont understand r u sure its ram i thing its phone memory ram and the phone memory r not same
😞 ive got a uk 3650....i tried holding down the pencil button whilst loading my phone and its crashed it!I cant get my menu to come up or use any apps except the apps ive got set up on my soft buttons.my battery bar has also gone!!when i load up my phone it says "app closed startup wserv 7"
