Geek might be a bit harsh here, but not every P800 user is likely to make use of these. MobilePenTester is a small application that when placed on a P800 will allow you to perform remote (security related) assessments over a GPRS or GSM connection. NetScan is a portscanner for the P800. PDAZapalows you to image the device's flash to a Memory Stick.
PDAZap is a small application that when placed on a P800 will allow you to image the device's flash to a Sony Memory Stick Duo. This can be used by forensic investigators and/or security researchers alike.
@stake NetScan is a very small TCP and UDP port scanner for the SonyEricsson P800 platform. NetScan uses AppForge libraries, requiring AppForge Boost for the P800 to be installed.
MobilePenTester is a small application that when placed on a P800 will allow you to perform remote assessments over a GPRS (2.5g) and/or GSM (2.5g) CSD data connection. The utilities contained within MobilePenTester are:
* PDACat (Netcat like functionality for a PDA)
* URLScan (common URL scanner)
* ULookup (used to look up the numeric codes of the URL)
* NetScan (portscanner - UDP and TCP)
* WAPScan (a port of @stake wapscan to P800)
NetScan and MobilePen Tester are available from http://www.atstake.com/research/tools/vulnerability_scanning/
PDAZap can be obtained here:
http://www.atstake.com/research/tools/forensic/
