Power Patch 3 with 30+ features (One Click Installation) by HaRRy
0 replies · 42,726 views · Started 02 October 2013
Get All Cfw features without flashing.....!!!
One Click Installation....
Power Patch� with 30+ features....
Platform:
Original Nokia Belle Refresh,
Nokia N8,
Nokia E7,
Nokia C7,
Nokia C6-01,
Nokia
X7,
Nokia Oro and
Nokia 500
(Check Ur Platform first b4 Installation....Do not try on other Platform....)
Total items:
Power Patch v1 by Normas Interruptor..
1. Belle base pkg_theme effect 4m E Drive
(Copy ur All new theme Effects file to e/effects........Go to setting n enable theme Effect......reboot your phone)
2. Browser cache to E Drive
3. profiles Editor
4. joshlog patch
(U can Change Avkon2.mif [status bar] from E/resource/app......just rename c/sys/bin/AknIncon.dll to AknIcon.dll.old.....reboot phone.....now u can change Avkon2.mif with new'one....after den Rename back c/sys/bin/aknIkon.dll.old to AknIcon.dll.........n reboot ur phone)
5. Kinetic scrolling
6. Send protected files
(sis, sisx, jar, jad etc)
7. tactiles v2
Other Patches...
8. Unlimited Home Screen
9. Restart Key at Power key
10. New windows 7 StartUp Screen
(U can Change it from c/Data/HaRRy
11. Bootscreen like Windows
(u can change it from E/Resource/App/Splashscreen.mif)
12. Windows'Xp startup tone
(U can change it from C/data/HaRRy
13. AppRename & Sub folder Enable
14. Voice Recorder 12@256Kbps
15. Camera Sound Mute
(Now...U Can Mute ur Camera Sound)
16. Battery Level Fix
(100>70>50>35>15 to 100>80>65>50>35>20)
17. ChangeMacAddress
(Just install ChangeMac.sis from e drive & apply Pach ChangeMac.sis.Rmp......now mu can edit ur Mac address from e\ChangeMac.Dat)
(Not for all Phone)
18. All Imp\useful Patches (40)
(Apply from RomPatcher)
19. Memory Card Icon
20. 4x11 KeyBoard
21. Fast ScreenRotation
22. DOLBY set 4m Equalizer
23. Unlimited Logs
24. Download Resum Enabled
25. Gallery & Music
Folder Search Added
26. Java Permission Mod
27. PopUpUi Improvement Mod
28. xCap Cache Increase
29. Connection PopUp Enabled
30. Coool widgets
enjoy...
☺ HaRRy� ☺
Download Here.
-Harish K. Patidar
NEXT UPDATE:
Advanced Power Patch v4 by Ha��y�
ChangeLogs:
>more Widget
(Compass,Homescreen Calc , Tras. Battery etc.)
>Unwanted App disable
>AppAutoStart
Add any App to Autostart from..
C:\Startup\Startup.txt
(Not need to any App like Appskeeper or ....)
>After Installation all media'll b AutoRefresh
>SpeedyGo Acceleration 1.6
(Experiment)
>>Install Or Delete any Patch, .mif Files in One click
i.e..
1. If u want to unInstall Memory Card Icon...just Rename
to
101f8764.txt
& copy it to
C\data\startup
Now click On Minicmd Icon
Done...(Restart Ur Phone)
2. If u want to Install Memory Card Icon.....just copy
101f8764.txt (Original File)
to
C\data\startup
Done....(Restart Ur Phone)
3. If u want to change Avkon2.mif or Other .Mif Files....Copy all
to
C\data\startup
Now Click on MiniCmd Icon
>>AutoChange Avkon2.mif (Battery\Status\Top Bar)
Just Copy Ur fav. Avkon2.mif to
c\data\startup\
& restart Twice ur Phone by Using [url="http://upfile.mobi/download.php?f=264795&p=51c8b542cc37428334d0ce15b57e1574&key=64abbdc2cfeaeaa95bbd3f31ef36bb8d.jpg"]ReStart Key By Ha��y�
>>>BackUp & Restore
Now Format ur phone whenever u want...just install PP & All Data'll be back..
including:
Msgs,Notes,Contacts,Calendar, Settings, T9Dict,Logs, Bookmarks...etc.
>just Restart Ur Phone to Backup Ur Data
>Data'll be Saved on 'F' Drive
(wait for Next Version...if u Don't Hav 'F' Drive)
>4How to CheckOut B&R feature (Working or Not)??
1. Backup ur All data from file manager(Msgs, Contact, Calendar...etc)
2. Backur all(remain) data@ [url="http://PhoneCopy.com"]PhoneCopy.com (Notes...etc)
3. Install Advanced PP v4
4. RESTART TWICE ur Phone
(BE AWARE....First Restart for Restore & Next all for Backup... So plz Restart Twice ur Phone Using ReStart Key By Ha��y�)
Now u can Format ur Phone
5.After Hard Reset.....plz Install 'Advanced PP v4' as soon As Possible.....otherwise...It'll Overwrite Ur Existing Data just like Nokia Sync
(Available Soon)
....Stay Connected.....
