ringtone problem
4 replies · 2,721 views · Started 04 August 2003
my friend called me on my cellphone and to my surprise i heard a different ringtone. it is not the one i saved but the default ringtone of se. i checked the settings and i am correct. i turned on and off my phone and now it's normal. 😮
this thing happened to my friend too.
has anyone experienced this also?
the ringtone could have beeen modified or something, like if you renamed it from umm, "ringtone" for example to "Ringtone" it would then go back to the default ringtone but upon restarting, it might auto detect it, i'm just guessing here :angel:
when my phone rings, you hear the first half a second of the ringtone, it cuts for a second then rings normally ... anyone know why ?
