Hi Folks
I have lost my earphones and boken the little stub on my key flip pad. (It is now a bit tricky to use the keys!)
I don't know how much they are but I'd pay �10 for a quick deal.
Cheers
Jago
Hi Folks
Cheers
Jago
i left my earphones on a bus on sunday, i'm gonna just get a 3.5 mm to 2.5 mm converter and use some proper sony earphones,
Thanks for the suggestion nk8 8)
But I wan't the original so I can accept/make calls as well.
(Actually what I really want is a bluetooth version but as several threads have shown this isn't there yet!)
I'm also reluctant to shell out �30 for the executive kit when it's only the earphones I need.
PS - managed to order a new flip pad from SE repair centre in the UK: Celestica on 01952 230 402 (Very quick and helpful)
Cheers
Jago
Cheers
Jago
[quote="Jago"]
Cheers
Jago[/quote]
how much was it?
The headphones you can order from here:
http://www.p800er.com/product.asp?id=87
The disadvantage is that you'll get (and have to pay for) that other stuff as well, while you might not need it. And it's out of stock right now :-?
And you can try this
http://pc-mobile.net/sp8aa.htm
That way you can use your normal headphones, accept calls and change the volume
NK8 - The Flip pad costs �11.75 (�10 plus VAT)
Delta737 - Thanks for the link - I'd forgotton about that 3.5 plug adapter - could be a goer! 8)
