Any app like this?
4 replies · 1,373 views · Started 05 August 2003
Hey,
I was wondering if anyone has heard of any app where I can program for SMS's to be sent at particular times and dates to people that i can define. A sort of a reminder service sort of thing. Like an extention of the calendar i suppose.
Thanks,
CJ
From the current issue of the Your Symbian newsletter http://www.yoursymbian.com
One application that seeks to make things even simpler for the Series60 user is
CoolMMS by Wireless Central (http://www.wirelesscentral.com.au). It costs $16.95
and with it you get such a vast amount of functionality for sending multi-page
MMS messages. That�s not all either! You can plan messages for a set date and it
facilitates the use of templates. Now the list of features I�ve read has nine
items in it. Far too much for me to go through them all here, but there is a
demo version which you can use to try the thing out.
Hey,
Tried coolMMS but it needs a connection to a server and is way too much than what is required. I'm sure it would be simple to create an extention of the 'drafts' functionality. All one needs to add is an ability to set time and date options to messages in the draft folder so that they can be sent automatically.
Domi......you listening?? 8)
CJ
