MMC Locked !!!
8 replies · 2,786 views · Started 05 August 2003
hi, my mmc on the 3650 is locked and i dunno the passwword. is there neway i can access the card without going to nokia for a firmware upgrade.
my friend got a used phone and the card is askin for password. plz advice if there is ne way or ne password for this problem. thnks ppl
[quote="Jesal"]hi, my mmc on the 3650 is locked and i dunno the passwword. is there neway i can access the card without going to nokia for a firmware upgrade.
my friend got a used phone and the card is askin for password. plz advice if there is ne way or ne password for this problem. thnks ppl[/quote]
If you don't need the data on the MMC card, why not format it in a MMC reader / writer? Then you could access it (i think).
even u have the mmc reader u also can't format it, the only way is to buy a new one
if the phone can be formatted with system tools there is gotta br some way ppl ? ? ? ? ?
[quote="Jesal"]if the phone can be formatted with system tools there is gotta br some way ppl ? ? ? ? ?[/quote]
Hi there!
You may use a card reader or any camera that has the ability to format the MMC card.
its very simple , if you are to any prior software version than 3.14 , such as 2.50 , you can find a file called mmcstore in C:\System on your phone. If you don't , then the mmc reader will do just fine. They are cheap and easy to use.
Analysis: 3.14 and above use the mcc and the phone's system file to check the password. Since the system file is jiborish to you and only the phones sysap can untangle and read, you use the mmcreader.
