any prorgam that transforms the 7650 into a radar detector?
7 replies · 3,150 views · Started 05 August 2003
yeah
its the same program that cooks food if you point your phone at it
using the software microwave emitter
soon they are developing a program that emits xrays from your phone so you can see womens jubblies
lovely !
PURPLEMUSTANG wrote:how about this app:
I f I can't post anything usefull let me crawl back to my cave.
:redface: so do i.... :icon13:
PURPLEMUSTANG wrote:With all the programs we have for the 7650 ,isn' there one that transforms it into a radar detector?
Try this out for size......😊
`Your Nokia cell phone can be programmed to pick up radar speed traps, when programmed your cell phone picks up the radar and alerts you on the message alert tone.
1. Enter your menu
2. Select settings
3. Select security settings
4. Select closed user group
5. Select on
6. Enter 00000
7. Press ok
8. Clear back to normal, within a few seconds your phone will display a radar sign with five zero's next to it. It is now activated.
Unfortunately only Nokia phones have this function. Cell info display needs to be de-activated. Settings -> Phone Settings -> Cell Info display
Each time you turn off your phone, or even each time you loose contact with your carrier, you�ll have to activate it again... It is done by steps 1 through 5, but the number (00000) will be already on the field as default. If you put the number 500 in the closed user group, and you go out of a store with detection ports thy will go off.
Please don't mislead people with B.S. like that. It is not funny as somebody might actually believe it.
