Is all the software for the Nokia 7650/3650 fully compatible with the Siemens SX1? I know they're both Series 60, but perhaps there are a few differences (screen-size for example), so that incompatibilities will occur... Does anyone know about this? If it is fully compatible it would be nice..
Software Compatibility?
Should be fully compatible. The SX1 has a 220x176 resolution display, but the 18 pixels beyond 208 are not usable/accessible for other than built-in applications (as a notification/indicator pane extension area).
Thanx! I hope you're right. That would make it an interesting choice (although I heard today that it has been delayed till October :-? )
