I have received my krussel cover today:
And it seems to be quite tight closing, when I put my P800 in it! You really have to pull the lid to make it close the cover as a result it closes quite tightly� a bit too tight�
Or is this normal? Anybody else same experience?
Are you using it with the flip? It will be tight at first with the flip as the leather has to stretch.
Once you have stretched it out for the flip, it will have slack if you go flipless.
[quote="rickpaul"]Are you using it with the flip? It will be tight at first with the flip as the leather has to stretch.
Once you have stretched it out for the flip, it will have slack if you go flipless.[/quote]
Hey you're right!
It fits just right with the flip, a bit tight but it fits.
(flipless it should have more slack)
thanx!
