how can i make skins on my 3650, how is the program called?? i really want to know. thanks
skins on 3650
sLauncher from www.symbianware.com
thanks
you can also check the Multimedia section for some skins 😊
do you know some other programs to make skins or sites to download skins??
There are a couple of others but none as good as sLauncher.
whatever you do DO NOT try WILDSKINZ from wildpalm as it WILL screw your phone!
Will
