hi is there somebody who has tried if u make a transparent background for smart memory will it be transparent or just plain white ??
Smart Memory transparent background
I use dazler smart memory skin.
It is simply great...
No, transparency is not supported by the .mbm filt type.
They only other way is the way Specialboy mentioned, dazler's skin. he makes wallpapers with additional smartmemory backgrounds, wich blend in perfectly. you can make these youlselve as well, dazler is making a tutuorial about this, which should be available soon... hang in there!
Made some new wallpapers, which include the smart-memory background!
have a look!
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=7666&start=15
