Hi pips,
Any body here in Phil. using a webviewer or anything like that? I cant make it work.. it tells me " connection error" or error=1909 or somthing, anybody knows how to set it? (here in Phil).
Before i was able to try, but that was like long time ago.. 😉
Thanks!
yeee.. u jst use gprs for ur connection.. it works fine on me..
Hey,
Sorry for the late reply....
Yea im using gprs...Globe postpaid line... can u give me instructions?
Does it matter what network ur using?
try this INTERNET send to 2951.
D mo n kailangan ng internet gprs!May bayad un and if u do,use netfront or doris kc may mga crack version.Webviewer wap gp lng ok n.Hanggang 10 access a day.Access un ung pag nagpaprompt ung use globe gprs.
Ok.. ill try muna yong gprs lang... its not dat badly needed na maginternet ako... Thanks!
if your Smart user no charge at all,even you use Opera. ang Globe tlaga mukhang pera :x
mga pards,
do you have idea kung saan makadownload ng webviewer sa wap.
yung nadownload ko may registration at error......
thanks....
[quote="The Party Boy"]if your Smart user no charge at all,even you use Opera. ang Globe tlaga mukhang pera :x[/quote]
What are you talking about? Smart was the first to start charging for internet and wap over GPRS, since November of last year! 25 cents per kb. Globe just started sometime this year, and though some wap sites are blocked, www apn is still free and it works with my webviewer. The only charged access point is internet.globe.com.ph
Mas mukhang pera ang Smart
sorry dont know that, coz my freinds telling me that if you using smart it's free.
Mga bossing, saan po nakakapagdownload ng webviewer? May bayad ba iyon or freeware?
Maraming salamat po.
http://reqwireless.com
visit the above link using your phone. trial version only.
