fm radio for nokia 3650
4 replies · 2,927 views · Started 08 August 2003
If i had a $ for every time i had answered this question,would've been a milionaire.
The 3650 has no FM hardware,hence,no software.
In the future,do a search before repeating a question and spaming the forum.
You can use RealPlayer to stream radio over GPRS with your 3650.
[quote="Anonymous"]You can use RealPlayer to stream radio over GPRS with your 3650.[/quote]Only if the radio station one wants to listen to happens to offer its programming as a Real Networks format audio stream (and you can afford the associated cost, as it could get quite expensive; depends, of course, on the operator & the subscription plan they offer).
the name of the sofftware you search for is:
avec radio
radio player for 7650/3650
mfg gegy
