P800 �499 CarphoneWarehouse September
4 replies · 3,192 views · Started 02 August 2002
The Carphonewarehouse expects the P800 in Sept for � 499. Too bad I promised myself I would never spend more than �199 on a smart phone :cry:
Surely you didn't think it was going to be �200 or less.
Also, I assume/hope that is �500 without a contract. So, with contract should be more like �200-�320. That is around �50-�70 more that the 7650. My current carrier reckons it will be around �250-�300 to upgrade, but that assumes he knows what he is talking about.
If so, my contract is over 12 months old so an upgrade should not be a problem, I'll even change number and get a new contract instead if the saving is significant.
Zuber
Sorry, I didn't explain properly, I posted the item as info, the �200 was just my spending limit! I'm pretty happy with my 9210 - I love having a keyboard. But I'm looking for another phone to compliment it, something quite small and light for when I'm out, but I don't want to spend more than �200. Also I'd like to have MMS feature too 😊 I was thinking about the Nokia 7650, but it looks big. Is it possible to sync contacts and calender between a 9210 and 7650? I know they both have IR but is there a means to auto-sync directly between the machines? (not just send via IR a single contact)
Don't know about sync. between the devices, but you might be able to just take the data files for contacts and calander from one ane overwrite them on the other.
I'm just guessing, by the way, not tried it. I don't even have a 9210 anymore.
Zuber
