Copying 'My Folders' SMS to SE P800
6 replies · 1,914 views · Started 09 August 2003
Hey ppl, finally i got my hands on the mineral gray p800 after having the longest decision making charts in my life = still happy with it . 😃
but i have a minor problem that i need the help of the seniors over here, I would like to transfer all my previous sms messages from my nk7650 to p800 .. is it possible ? pls help and guide...thanks.. all other things can be sent thru bluetooth or ammendments by myself, but i cant afford to lose those precious sms..pls help...thanks a lot.
mike 😮ops:
Once you have set up the contacts list, maybe you could use your SIM to transfer the messages? Seem to remember when I first (very first) booted my P800, all my old messages were still there on the SIM, and I think I moved them to phone memory.
Maybe by shuffling the SIM between the two phones you could get anything important across.
OK, but there is a "Move To/From SIM" option on the P800.
Is there an equivalent on the Nokia?
Sorry to bother both of the seniors.. i think i have solved my problems but not to the extend of what i had in mind.. :cry: ..
i installed a software - MsgSaver into my n7650 and backed up all my important sms into a *.txt file.. then send it across to my p800 thru bluetooth.. haha.. :-? .. its not in the form i wanted...at least the information needed are still available.. thanks anyway for your help
If you still have your messages on the 7650 i think i have an even better solution.Have you heard of Desktop Message S60?It allows the user to send SMS from one's PC and to archive SMS's in theirs true format.There is an UIQ eqivalent of the same app,Desktop Message p800.I haven't tested this,and i don't know if it'll work but you can download your messages from the 7650 using Deskotop Message S60 and after that you can(Maybe)upload them to the p800 using Desktop Message p800.
Anyway,it wouldn't hurt to try.
