9210 V4.13 Unable to edit profiles
2 replies · 1,954 views · Started 10 August 2003
I own a 9210 with the V4.13 Software. It replaced my old 9210 with 3.XX-Software. I used my old Flash-Card and updated the SW on the Card. Now I want to edit my Phone profile (ring tone etc.). But when I select "Settings -> Profile..." the system says "Object not found", exactly "Hinweis Angegebenes Objekt nicht gefunden" (I use the german language setting).
There is also no menu item "profiles" in the menu on the phone side.
Does anybody have a idea what the problem is?
Thanks in advance,
Gerd
Last time I re-installed all Nokia data v4.13 (about 10 days ago), I found that it didn't install several apps including display, file manager and profiles. These aren't available as individual .sis files on the Nokia website either. In the end I re-formatted, installed the individual files I wanted from v4.13 (ignoring the ones you don't want saves useful space on the 9210) and then simply installed the v5.54 versions of the missing apps. So far, they have worked fine.
