when i turn on my mobile 3650 it shows syestem error every time
i go for menu but when i remove memory card i ts okay what can io do
syestem error
If you have a PC-based MMC reader, use it to reformat the card.
I have exactly da same problem!Wot is a PC based card reader?Do i hav 2 buy one?I dnt have a PC?Help!
I have exactly da same problem!Wot is a PC based card reader?Do i hav 2 buy one?I dnt have a PC?Why did this shit happened 2 my fone and MMC?Help!
It seems that you have double-posts. =)
Card readers allow you to access any type or removable storage such as MMC, SD, Memory Stick, Compact Flash and SmartMedia. They are cheap and easy to install.
If you do not have enough cash to buy one, you may want to visit any film shop and let them format the card. You may also visit any Nokia Service Center or borrow any digital camera which uses SD or MMC.
According to nokia the realplayer can only connect to url for streaming with orange is this true,also if you don't have a infra-red port on the pc can you download oplayo via gprs/wap 8)
[quote="mackem26"]According to nokia the realplayer can only connect to url for streaming with orange[/quote]It works with other operators besides Orange, too. Nothing Orange-specific in RealOne Player for Series 60.
Why is dis post here?!Were talkin bout card readers here!
