TRoubling Hello World
4 replies · 1,729 views · Started 11 August 2003
Hello.
I read the miniguide, used the makmake helloworld vc6 at the command line...
The probelm is, it says.
The name specified is not recognized as an internal or external command, operable program or batch file.
Is Perl, version 5.003_07 or later, installed?
Darn.
Thanks.
kobe24
Installed Symbian yesterday, the same thing happened. I found it pretty amazing that perl was needed to install this. Surely there is a wwin32 binary that does something similar!
Anyway, the solution: go to www.activeperl.com and download a copy of perl. I then changed my windows path variable to include "<the-path-to-perl-root-directory>/bin" (i.e. c:\perl\bin).
I also had to change another path variable elsewhere along the line, but can't remember where.
HTH,
Adrian
Ok, the perl thing work.
Problem is, it doesnt show in the emulator.
Emulator shows only the "SERIES 60" blue text.
Anyone?
Thanks.
Seriously, I thought it had broken the first time I tried to run the program. It takes my 633MHz processor a somewhat shocking minute or two to actually get to the phone app itself!
HTH,
Adrian.
PS: These forums seem a little inactive 😞
I got it, I had to edit my epoc.ini replaced the C: with D: since i installed my symbian to D:
