Messaging not working with my Nokia 9210i
4 replies · 1,668 views · Started 11 August 2003
i've formatted my Nokia 9210i V5.34 for a while, when installed all the necessary applications, i noticed that my phone is not able to write short messages. !!! even it is not receiving short messages properly.
what would be the problem ?
Thanks :-?
had the same problem before, do you have MMC? If you have and you save your messages to MMC, after formatting the Phone will create a new messaging folder, then you'll have one in COmmunicator/System/Mail and one in MMC/System/Mail...
anyways that's my experience and my phone was confused so all my messages weren't coming in and I wasn't able to send SMS also, What I did was I format my MMC and then the problem was solved...
Thanks for your reply
i've formatted my MMC and didn't care about any messages, but the problem still there, so i formatted my Phone again and MMC at the same time, but the problem still ON !! ..
what should i do ??
buy another one ? :cry:
