i have had my 7650 since 27th july so far i can work the phone i have wap configured but when it comes to sending pics i have to define access points cant do it i dont know what to to or where and i cant do email as i know nothing about configuring that either so i cant install any program
so all i use the phone for is calls
taking pics and deleting any help would be great as iam not using this phone how it should be used :cry:
help
where are you ? mine came with a sheet with destructions for setting up btopenworld, which is handy cos im with them !
[quote="Anonymous"]but when it comes to sending pics i have to define access points cant do it i dont know what to to or where and[/quote]
Do you want to send pictures as MMS messages to other phonrs? If yes, then you need to use your cellular service provider's MMS settings. It is usually a GPRS profile that points to your operator's MMS server. If your operator doesn not yet offer MMS services, you can send pictures as email attachments (see below).
For emails and other Internet applications you need to have an Internet access point configured.
You should contact your cellular service provider (=your operator) and ask them for correct settings. They should a have customer care website or telephone number. You can also tell us what operator you are using and maybe someone of us can help.
Tero
i am with orange pay as u go but i can change to contract if that would help me with settings mms email ...and bluetooth does not work either on this phone i can pair up devices but it says failed messages i got bluetooth as email and mms i cant configure now this does not work... are the other settings supposed to be configured before bt will work
