More RAM
5 replies · 1,994 views · Started 12 August 2003
Hi i was wondering what i can do to get more RAM? Do i have to have a small sized backround image etc.? Thanks
You can't get any more RAM than what's in the phone when it leaves the factory. 😉
However, you can free up used RAM by removing all software installed in RAM/phone memory and reinstalling on MMC.
You can also move messages & images from phone memory to MMC.
You can also remove all old (or simply all) calendar appointments, tasks, notes, unnecessary contacts (unnecessary contact details), thumbnail images, wallpapers, ring tones, browser bookmarks, ...
In other words, the more of your own data you store on MMC, and the less you store it in phone memory/RAM, the more free RAM you will have.
RAM and phone memory/storage are two different things.If you want to have more RAM don't leave apps running in the background.You can also free up RAM by starting the phone in flight mode(You won't be able to receive calls though) or by using the sLauncher and charger trick.
The free trial SLauncher allows you increase more memory. I think it also has the ability to compress it. =)
You may also want to try the free trial SDoubler.
[quote="GhostDog"]RAM and phone memory/storage are two different things.If you want to have more RAM don't leave apps running in the background.You can also free up RAM by starting the phone in flight mode(You won't be able to receive calls though) or by using the sLauncher and charger trick.[/quote]
I have missed something I think! "Start in flight mode"? How? And what's the "charger trick"? 😉
[quote="mekeni2000"]The free trial SLauncher allows you increase more memory. I think it also has the ability to compress it. =)
You may also want to try the free trial SDoubler.[/quote]
That is not a real solution.
You can start the phone in flight mode with a third party app from www.psiloc.com System Tools.About the sLauncher trick,search the forum.
