was wondering whether anyone is facing the same "problem" as me. I've downloaded the aquarium animated screensaver but the problem is, when the screen saver come on, it only fills a small portion in the middle of the screen. Is it possible to somehow "stretch" the screensaver such that it fills the entire screen? I am facing the same problem with other "small" screensavers
I've searched the forum but nobody seems to have this problem, would greatly appreciate any help
thanks in advance!
try to resize it to 208x320 😊
im gonna post this here - cos i dont want to needlessly flood the main forum.....
Is there an app that lets you select a number of images that are in your memory and then cycles them as a screensaveR?
that would be cool - if anyone knows one - tell me!
thnks alot
Why not create an animation with all the pictures you want then use that as a screensaver?
Thanks Party Boy 😊
is there any software I can use to resize it? I can't use the Sony Ericsson Photo Editor as that can only save images in bmp format i.e. still images
try this
Resize, crop, add text, replace color, add/remove transparency - go to http://www.gifworks.com/
Fast and free GIF image editor
