I have j2me and also game installer, jad generate to jar but i dont know how to use with j2me, please help me!..
Jackie
How to test java game with J2ME?
You'll have to give us a little more info - ie what type of phone etc.
In the case of 3650/7650 the most common and easiest way to install a Java game is to send the .jar file to the phone vir IR or BT.
The file will show up as a new message.
When you open the message from your inbox, the game should install
itself.
You will then find the game by clicking on the Apps icon in the menu.
(the above information is in the user manual) 😊
Thanks too much friend, yeah my model is 6610, and I have game for serie 40 with only jar and I ganerated it into jad and then I install with Game Installer, and the I got the message (Operation fail!) I use PC Soute 7250i, and one more thing, can you tell me how to test the game java on pc with j2me?
I'm no expert on that, but you can download all necessary tools for that (including the emulator) from nokia's website (http://forum.nokia.com)
