after i unzip the game it leaves me with all these files i don't know what to do with. i've seen other games like this too. what do i do to install it?
tiger woods instalation problems
rename the extension to .jar
assuming u r using windows go to tools - folder option - view - untick the hide file extension
then rename the file from eg. tiger.zip to tiger.jar
Next step is to transfer the .jar file to your phone.
I use BT to transfer it, so it lands in my inbox. When opening the "message" it asks if you want to install.. answer yep and viola.. it should be installed. (the message can be deleted after it has been installed)
You can find the installed program/game in the 'programs' folder 😊
i'm pretty certain that if you bought the game, you wouldn't have to do all this, although i may be wrong.
