which COM!
4 replies · 1,498 views · Started 15 August 2003
HI im havin probs sendin info from my 7650 to PC ive been lookin at the advance options of my bluetooth and ive noticed u com says 3 and then another says 4 and i had a look in device manager in the ports and the must be 10 different coms how the hell do u find the right 1 and cud this cuz my 7650 to fail in sendin items to my PC helllllllllllllllllllllp 😮
What do u mean try checkin the ports and im using driver Version:1.3.2.7 which is the latest 1, im hopin some1 can help me out there cheers all. :cry:
I'm having the same problem!! Mrouter shows all COM ports "not connected". My settings for seral connection are on COM4, but as soon as I want to connect serial there's a message: "serial connection on COM 0, any application for BT should use COM0 (or something similar)! Which is the only one not in mrouter. When I push the OK button then, PC tells me: "device closed connection..."
Pleez someone help, I'm getting desperate
