Is it possible to rename the contacts.cdb file in System\Data so you can copy another (updated) copy to the P800?
Is there an app that will allow you to backup/restore the Contacts then?
I always get File in Use message.
Would be really nice if there was a way to edit the Contacts on a PC and it syncs with P800 (besides Outlook (Express)).
Rename or manually backup/restore contacts.cdb
Try this thread;
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=9298&postdays=0&postorder=asc&highlight=contacts%20cdb%20zip&start=15
