I don't have gsmbas.lib in my sdk, while the header file exist, can i
download the lib file or i should find newer sdk
Regards,
Ahmed :agrue:
Missed gsmbas.lib
i have the same problem, only the .lib missing is ShapeListManager.lib
flicker82 wrote:i have the same problem, only the .lib missing is ShapeListManager.lib
i have same shapelistmanager.lib missing, anybody know i can get this file?
The shapelistmanager.lib is not contained in the sdk, but you could compile the project under C:\Symbian\8.1a\S60_2nd_FP3\Series60Ex\guiengine\engine to build it.
