Has anyone got SANDISK 128MB MMC with 3650?
I have bought this card.Yes it worked but with eti camcorder pro i couldn't record all of sound of the videos. I want to know:Are they full compatible?
It is said that the other cards don't make an error like this with the program.
But it is a bit strange because in other apps there are no problems on my phone.But with Nokia's original 16MB card i can use program normally???
Sandisk 128MB MMC+3650 are compatible OR NOT?
If it worked wid other apps or anything in ur fone then da SANDISK works,as simple as dat.Maybe u just dnt know how 2 use ETI.
well it should work.. my company sells SanDisk Media Cards and i've been using them since too and they always worked!!
