Wich PC program can create MBM ?
Create MBM
bmconv.exe if you want to use DOS is the best bet, same as the old EPOC days!
bmconv.exe if you want to use DOS is the best bet, same as the old EPOC days! You can find it in the Series 60 or 9210 SDK.
