Tracker and Error #3
1 replies · 1,234 views · Started 18 August 2003
I installed the demo version of Tracker 2.0 and when I try to run it, I get an error the my phone identifies as "#3" then tracker shuts down. I have tried to install it twice, but get the same error.
Anyone seen this before. I am running the original firmware that came with the phone. And I am sure that someone will suggest a firmware upgrade, but I am in the US and it is not as easily done here as it is elsewhere. I don't really want to send my phone to SE and have it gone for 8 weeks.
Yes, it's weird huh?
Install Tracker Demo. Then before you click on it, open the Calender and the To-do feature..... (you only need to do this once)
Now, click on Tracker and Voila! It should be running smoothly.
Don't expect me to give you an explanation on why this is so. It just is. 😃
