what is a .prc file??? please read
4 replies · 15,560 views · Started 19 August 2003
i just got the holy quran in .prc format but dont know how to use it?? its in my inbox but is an unknown file format to the phone!
help!
how do i use the file??
I used the following search string on Google:
".prc" +file +format
The results seem to indicate that it could be a MobiPocket file format.
That search took all of 0.63 seconds to execute.
I'll leave it as an excercise to you to try searching for "MobiPocket".
Or,you can try eBook reader from www.symbianware.com .Also,you can convert any .txt file to eBook Aportis (.prc) format with eBook maker(which is freeware)also from symbianware.
If you go to www.mobipocket.com they have a free mobile reader and the pc addition. Once you download the reader you can install the .prc file by syncing the phone. I use mobilepocket all the time and I love it!! Plus you can get alot of freebooks on their site.
I too have downloaded and installed mobireder to my nokia 6630 but it wouldn't open, maybe because my hp only read .sis file extension.. this mobireader is in.zip extention...any program to open mobireader in my hp? thanks
