Preventing unintentional button press
2 replies · 1,711 views · Started 20 August 2003
Even after you lock the keypad using left-soft-key and *, when there's an incoming call, the answer and reject buttons become active.
I use the original nokia leather holder for my 3650, but it's quite a tight fit. When I get an incoming call or my calendar alarm rings, in the process of taking the phone out using 1 hand, the buttons can be accidentally pressed. Can be frustrating if calls are rejected, or alarm message are not seen and I've no idea if it was a snooze or stop that 'I' had pressed. :cry:
Is there any solution out there?
[quote="boon"]Even after you lock the keypad using left-soft-key and *, when there's an incoming call, the answer and reject buttons become active.
Is there any solution out there?[/quote]
i also have the same problem with that kind of leather case.....just have to be extra careful when getting your phone out....
[quote="arvin1x"]i also have the same problem with that kind of leather case.....just have to be extra careful when getting your phone out....[/quote]
I miss taking out the phone using one hand, and I still reject calls or snooze/stop alarms at times when I didn't intend to. 😞
