Does anyone know how to get the original screensaver background back? Using eFile Manager I can see a file called backgroundimage in the system folder and from what I can see when you select your new image it gets copied here and renamed to the above but I can't find any jpegs which relate to the original image.
:roll:
Default screensaver
yep - go to settings and restore defaults... this will bring it back
...problem is that you will lose any other custom settings (not operator logos though) at the same time so will have to re-configure...
using efileman find the same file in the z: drive folder (the same file and folder name as c😊 Z is the image of the firmware and is not overwritten by system changes.
