mpeg version not compatible??
4 replies · 2,768 views · Started 21 August 2003
Over the past 3 months I have with more or less success tried to convert mpeg movie clips to mp4. Mostly, I am trying to convert mpegs taken by my digi cam Sony PCS5 (2 years old).
While good picture quality is quite easy to get, I constantly fail getting audio. I have previously tried PvAuthor and Quicktime.
My latest attempt was the Movie Maker demo. Again I failed getting audio but the software provided me with the information that the mpeg file was in an unsupported format! 😮 I thought mpeg was mpeg!?? :roll: :roll:
Is there anybody out there who can provide a workaround/explanation? Maybe I can export my non-standard mpeg clips to standard mpeg clips using some kind of converter software...?
Any help would be highly appreciated.
Try using TMPGEnc to re-encode to mpg first. Havent downloaded this software for a while but last time I did it was free to encode mpg1 you only had to pay if you wanted to encode mpg2.
http://www.pegasys-inc.com/e_main.html
Thanks for your responses guys!
It seems from your suggestions and the lack of other posts that there is no easy way to audio on these "non-standard" mpeg files.
i always use AAC 64kps 44000mhz (using pvauthor) and the sound sounds really great :angel:
