Hi all,
since i use the 9210 during work hours and the 7650 in the weekends i'd like that both the phones turn in "quiet" mode during weekends (the 9210) and working days (7650) enabling a "silent" profile. (i need this because the two phones are synchronized).
There's any utility out there?
thaNKS
Maybe you should try SmartProfiles from www.symbianware.com
yep, e-profiles pro has an option to automate by time and day different profiles.
Eck
Thanks,
since Smart Profiles will cost 8.95 Euros for the 7650 version plus 10 Euros for the 9210 version i'd like to take a look to EProfiles but i can't find it in the AAS software directory, any website available?
go to their website www.psiloc.com - you can trial both the versions of eprofiles pro (and you may just see some other apps you like as well 😉 )
Paul
