E scumm (HELP)
2 replies · 2,158 views · Started 21 August 2003
Im new to this forum and i tried to search for the answer in the forum but i didnt find it 😊
OK i installed the app in the p800 and i downloaded a game called Monky island...
How do i send the MonkyIslnad game to the P800?
And what should i do after sending the MonkyIsland game to the p800 to play the game?
Thanks for sharring 😊
It's no problem. I used my docking station to transfer them onto my memory stick, i put them in a dir called MI under documents. Then simply open ESCUMM, click on Add Game and browse to the directory (D --> Media files --> Document --> MI). You wont see any files listed just an empty appearing directory. Click Choose then OK. Finally click on the game in the list and click Start, there you go. The strip of characters at the bottom will let you enter the code you need/enter save game names etc.
Can .EXE files be used? I installed Monkey Island on my p800 but eScummVM does not recognise it. How do I convert an .EXE file to one understood by eScummVM?
