smallbase
7 replies · 3,161 views · Started 02 November 2001
Yes I agree, I suspect if the author out a little effort into the database he could achieve quite a few 9210 sales.
Rafe
I thought it had a card view which even allows you to create lists.
A card view is what it sounds like, rather than having lists or colums the data is diaplyed with one record to each page of a 'book'. Its like a card index wth each record being a card. Thus more information can be seen per record.
Rafe
Yes, you're right it's an excellent idea.
I'll try to implement a card view in a new release.
I plan also try to add a Long Memo type.
Thanks for your feedback
NP for the idea! btw i think if you can release this soon it will be an enormous success!!! The first data.app for ER6. You're lucky they've left it out. User posted image Mb it's best that you make it look and feel like on ER5, not?
Regards,
Jan
Hi Jan,
Good news!
SmallBase 1.2 available Now !
What's New in this version
*Long Memo field Type added (more than 255 chars)
*Card View added (removable)
*Find feature added allowing wildchars (? and *)
*Filters and Colors on Text type field allow wildchars (? and *) in the keyword
*Memory optimizations
*Empty choice lists bug fixed
*Memory leak bug fixed
*Copy, cut and paste bug fixed
Next step link between tables !
