Handy Day wallpaper questions
4 replies · 1,747 views · Started 23 August 2003
I'm thinking of getting Handy Day, but confused with the size of the wallpaper.
What size should it be in?
How about when you place those additional shortcut buttons at the bottom of the screen? Will the size be the same?
Doesn't matter what size. Handy Day will re-size the image to fit.
For example, I have a 1K 5X5 pixel Jpg of the standard greeny Windows 95 background which Handy Day re-sizes to fit the full screen (except the icons at the bottom).
I've also previously used a 640X480 photo taken with the P800 and that worked also.
ok resizing aside, whats the exact size ? so that the background would be clear and wont look stretched out
Can't remember off the top of my head, but someone asked the same question just after Handy Day 3.0 came out and someone (I think from Epocware provided the detail, so you should be able to find it with a search (came out 27th May if that helps???)
