Estabilishing connection to mRoute from the phone
5 replies · 1,909 views · Started 24 August 2003
There is a PC app that starts a serial connection when the device is in range.Try here: http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=14640
Not really,the app runs on PC.You don't need to have BT turned on the whole time,you can turn it on just when you need to connect.And even if you do have BT on all the time,it doesn't waste much battery power if there is no activity.
[quote="GhostDog"]Not really,the app runs on PC.You don't need to have BT turned on the whole time,you can turn it on just when you need to connect.And even if you do have BT on all the time,it doesn't waste much battery power if there is no activity.[/quote]
when i have BT conenected (no activity)
and BT not connected
the battery is moooore earlyer off
so activity on BT hasnt big role!
I find that hard to believe.I haven't switched off BlueTooth for a very long time now and i haven't noticed a big difference in the the life time of the battery.
Oh well,it must be my Super SmartPhone.
