1st my fone says SIM card rejected so i turned it off,turned it on again and everything went ok.The nxt time when i turned it on my fone says "phone start up failed contact retailer" so i turned it off and when i turned it on although it worked,it says "APP CLOSED MAIN".What does it mean?Is my fone messed up?I just upgraded to firmware 3.16.Pls help.So i can prevent dis fone 2 be sent 2 repair.Thank u
!!Start up help!!
Pls dnt reply 2 say that i hav 2 search here,im logging on WAP here,dnt hav a PC.
You need to get you phone refashed at nokia service point .Good luck
Try pressing and holding the abc key in order to bypass the startup procedure,if that works,you can maybe do a backup or hard reset.
have you installed any new software lately?? Try to think back to what you installed about the time it started getting those error messages.. I think it's 99% sure that a prog is messing up your system... My advice to you is to restore to factory settings, add progs which you KNOW work,add stuff that you usualy need/use and THEN make a total sys backup.. So, next time you install smtn that F***s up your sys, restore that backup and you don't have to go through hours of installing again and again... 😉 Good luck! Cheers
U have 2 again upgrde ph so it wl ok i had same pro last month
