Card Mover is a program designed to ease the problems when you get a new larger memory card. It allows you to move data from one memory stuck to another.
Author Notes:
Card Mover is an application designed to allow the easy transition of all the data and Applications to a larger Memory Stick. With a few very simple steps you can move the data directly from one card to the other. The time-consuming and complicated use of a personal computer is not necessary anymore.
Till now you had to copy the content of your Memory Stick to a PC before you were able to copy it back to the new Memory Stick. Using Card Mover application it?s possible for you to do that much faster & easier - directly on your SonyEricsson P800.
While copying the data, Card Mover shows you exact instructions to prevent an unintentional putting in of the wrong Memory Stick.
The Card Mover application has also a security system to help you in case of a system breakdown or user cancellation. In other words you will be able to resume the last cancelled or interrupted copying operation.
Your data is always safe, because it is never deleted from the source card.
All applications that are installed on the memory card will run properly after the copy process.
Card Mover is also a perfect tool to create a full backup of your data on your Memory Stick. This allows you to store a second memory card in a safe place at home while your device and the original card is always with you. So if your SonyEricsson P800 gets lost, you?ll have all your data on your Memory Stick at home.
