I am wondering if Realplayer can play audio files like a playlist on my 3650. I didnt see it in the options, and Im not sure if there is an addon that will acheive this. I want to avoid having to change the songs manually.
Thanks!
Thanks!
[quote="DrEvil"]I am wondering if Realplayer can play audio files like a playlist on my 3650. I didnt see it in the options, and Im not sure if there is an addon that will acheive this. I want to avoid having to change the songs manually.
Thanks![/quote]
You could do a .ram file with several entrys and it will act like a playlist.
I was thinking of that. I was just going to rip a bunch of cds in order and have them all encode as one file. Its for a long trip so Might work well.
Weird, the .ram file wil not play locally... is there a way around this?
I setup my flash card as follows:
2 files encoded in Helix (they work in real player)
a.rm
b.rm
added a .ram file to use as a playlist..
file://a.rm
file://b.rm
now, I get that to work in the 3650, but it tries to connect via wap connection. I want them to be played locally. Is there a way to play .ram files locally without having the phone connect to mms?
TIA.
