c:\ ???
4 replies · 1,425 views · Started 26 August 2003
Hi
I tried searching through this forum ... But seeing as I don't know exactly what I am looking for I can not be sure it hasn't been posted before ... sorry 😞
But get to the point ... I have seen various topics on other boards & in the manual that came with the phone about putting files in c:\xxx\xxx ...
It said I should be able to do this with the suite, but all mine shows is stuff like installation, images & video folders ...
Can anyone point me in the correct direction ...
Cheers
BSK 😃
you have to buy an explorer for your mobile, you can get one from psiloc.com or handango.com
it lets you browse your mobile like a windows browser does on your pc!
PcFilemanager from epochware will do the trick, it opens your phones internal drives in a windows explorer type interface on your PC.
Will
You don't have to buy a file explorer for your mobile,you can get one for free, FExplorer from www.gosymbian.com
Thanks very much for all the info ... Now off to try it ...
BSK 😃
