anyone here can help me on how to clear the log file for installed application on 7650? pleeaseee help....
thanks in advance
thanks in advance
use the FExplorer app. go to install folder then delete the file install.log.mpk
hope this helps. 😊
why would you want to do that???
[quote="girosky"]use the FExplorer app. go to install folder then delete the file install.log.mpk
hope this helps. 😊[/quote]
I hope you didn't do what girosky said.Messing with your phone's file system is one thing you don't want to do.BTW: The .mpk exstension is probably the effect of some space compressing app,like Space Double,so if he doesn't use SpaceDoubler he will never find a file named install.log.mpk.
i just got this idea from this forum. I am not trying to break up his phone. I just want to help.😞
