SYSTEM.INI
4 replies · 1,991 views · Started 27 August 2003
Is it advisable to delete it?It says no related application installed.I suspect it is messing my phones start up.Also in da c://system/bootdata,there are files dat also hav no related application when i opened it.My phone prob is dat when i turn it on sometimes (not all da time)it says start up failed contact ur phone retailer or even sim card rejected or it opens but a msg window appears sayin MAIN App closed.
If you actually look at the files you will see that they contain information ...
You do not delete these types of files ... Cause if you did ... Your phone would prolly fail ...
BSK 😃
hi
i had a similar problem with my phone when i installed wild skins! it totally messed my phone up and would give me 101 error msgs on start up and then tell me to contact phone retailer coz it failed to start up!
after hours of surfing the net and reading alot geeky stuff i concluded that i needed to simply delete the system.ini file and restart the phone. the default file (which came origially with the phone) will then be loaded and that should fix the problem!
well it did for me! 8)
