Bluetake BT007
9 replies · 2,489 views · Started 27 August 2003
ive brought myself the above item and installed it with the latest drivers but i can send from PC to 7650 but cant send from 7650 to PC i have windows XP pro can any1 tell me why it isnt working cheers all 8)
Are you sure that you have the latest the drivers?I had the same problem with my MSI Bluetooth and the drivers that came from the CD.I fixed my problem by installing never version of the drivers.
BTW:This topic has been widely discussed in the forums.Do a search.
yeah the drivers are the latest version Version:1.3.2.7 ive checked throu this forum and done a few things but still i cant get 7650 to pc to work im totaly lost
Try this thread: http://allaboutsymbian.com/phpBB2/viewtopic.php?t=3075
There is a registry fix that might help you.Its not guaranteed to work.
Cheers ghost but i already checked that and it was set to the correct reg already so again i dont have a clue why it dont work if any1 does plz plz let me know. 😃
Well,BlackWolf,sorry,i'm out of ideas.Maybe you should try drivers from other vendors,like MSI.if i'm not mistaken BluetTake uses drivers based on the WIDCOMM stack,same as MSI.If it doesn't work,you can always uninstall them.
http://www.bluetake.com
They have the generic drivers for all the versions of their bluetooth dongles. I have one, and it works fine and im usin the latest drivers.
DB
When your computer start, hit the setup button (F2) I think. There might be a feature called 'USB Emulation'. See if this is set to OFF. If it is, then turn it on. Restart PC and try again. Hopefully it should work.
Cheers,
CJ
