pls help re: latest cam api
1 replies · 1,541 views · Started 28 August 2003
hi, new to using codewarrior so still not familiarlise yet......
I import the *.mmp from the samples folder upon extracting
its fine however when i try compiling it. so much error appears
main one was the
Error : the file 'ECam.h' cannot be opened TestCameraApp.h line 15 Error : Compile failed
so i tried adding the Ecam.h file into the source folder and compile again
the next error was;
Could not find or load the file "ECAM.LIB" for target "TESTCAMERAAPP WINSCW UDEB" for project "TestCameraApp.mcp".
any idea how to go about solving this problem
thanks.......... 😊
finally i managed to get it compile and running in the emulator
And think its a P900 Cam Api and not the P800 one
